Activity Forums Maxon Cinema 4D Animated Graph
  • Animated Graph
    Posted by Dana Portenier on January 4, 2017 at 10:05 pm
    Sorry for newbie questions do most of my work in AE. I have extruded the 50 states of US and want to animate a graph that will change extrude height based upon CDC data for a amount a disease in a state. I would like to automatically link the depth of extrusion to a hue/color change based upon extrude value entered which will be based upon prevalence of the disease in the state at that point in time
    Adam Trachtenberg replied 9 years, 8 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 5, 2017 at 5:18 pm
    The way I would do it would be to put the extrudes into a MoGraph Fracture Object and then apply a Shader Effector to the Fracture Object. The Shader Effector would be set to scale in Y, and in it’s Shader tab I’d load a texture with the appropriate color values.
    The easiest way to set this up is to create a plane covering the shape of your map and give it a material with the texture showing your state color values. If you put the texture in the color channel, for example, you would then go to the Shader Effector’s shading tab, set the Channel to use Color, and then drag the texture tag from your plane into the Texture Tag box.
