Activity Forums Adobe After Effects animated gif quality issues w/ 5.5
  • animated gif quality issues w/ 5.5
    Posted by Jeff Blasczyk on March 5, 2006 at 12:57 pm
    I was wondering if anyone knew the reason my gifs turn out pixelated?
    I’ve just kind of been messing around with it.
    My settings are:
    color palette: system
    transparency: none
    dithering is checked
    thanx,
    jeff
    Filip Vandueren replied 20 years, 6 months ago 2 Members · 1 Reply
  • Filip Vandueren
    March 6, 2006 at 11:56 pm
    The pixelation is probably the result of using non-system colors in your comp.
    On the whole: you should never use the GIF-export of AE.
    If you have it, use Photoshop/Imageready to convert a sequence of picts or psds or whatever to a gif. It will calulate the best palette for your animation.
