Activity Forums Adobe After Effects Animated Gif from Video
  • Animated Gif from Video
    Posted by Lay.z.boy on July 7, 2006 at 2:45 am
    I have a sequence of PNG’s and I have imported them into After Effects. I would like to export it as an animated GIF to post on forums. When I go to File>Export, there is no GIF. How do I export it as a GIF?
    Thank you
    Mandarina replied 20 years, 2 months ago 3 Members · 2 Replies
  • Colin Braley
    July 7, 2006 at 3:52 am
    First of all in After Effects you can either export or use the render queue . I always use the Render Queue, its more flexible and has more options. To make an animated .gif use the following:
    – Set up your comp
    – Add your comp to the Render Queue (or press Ctrl + Shift + / )
    – Click on “Output Module” and go to “Animated Gif”
    ~Colin
  • Mandarina
    July 18, 2006 at 7:48 am
    i usually use special video-to-gif converters (for ex. by geovid.com)// they work with all video formats & transform video files to gif animation)) you can create cool avatars & logos! the convertion is as follows: you choose input & output files, select size & quality and push the `start` button! the rest is done by the converter!!
