Activity Forums Adobe After Effects Animated film strip
  • Animated film strip
    Posted by Snoskatedude on June 23, 2007 at 7:07 pm
    I have these rotating “film wheels” and I want a “filmstrip” to be animated going around the wheels. So it’s basically a white line going around some rotating wheels. The problem is having a long line (the film strip) being bent around multiple wheels and still extending. How would I go about doing this?
    here’s a still from the project
    [img]https://i67.photobucket.com/albums/h293/snoskatedude/SCREEN.jpg[/img]
    Aharon Rabinowitz replied 19 years, 3 months ago 2 Members · 5 Replies
  • Aharon Rabinowitz
    June 24, 2007 at 3:00 pm
    if it;s just a whte line (i.e., you can;t see the actual filmstrip – just the side) why not make a stroke. Creat a solid, and then make a path using the pen tools that follows the shape of your film strip.
    Then apply the stroke effect (Setting it to stroke your mask, and to composite the stroke on transparent).
    Effect > Generate > Stroke…
    Aharon Rabinowitz
    arabinowitz(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
  • Snoskatedude
    June 26, 2007 at 5:17 pm
    Thanks, but how do I animate the stroke?
  • Aharon Rabinowitz
    June 26, 2007 at 5:33 pm
    That depends on what you’re trying to do. My understanding was that you just wanted a line.
    If you want segements (a broken line) that can cycle over and over, you migth want to look into the vegas effect, BTW.
    But to animate a stroke, play with and animate the “start” and “end” properties.
    Aharon Rabinowitz
  • Snoskatedude
    June 26, 2007 at 5:36 pm
    Is it possible to make an object and animate on the path, but how do I get the object to stay oriented onto the path?
  • Aharon Rabinowitz
    June 26, 2007 at 5:53 pm
    Yes, you can copy a path into alyer’s position from a mask by following this tutorial:
    Watch Me!
    Regardless of how you make your pathe (whether through a mask or just animating by hand) you can have the object orient along the path by choosing Layer > Transform > Auto Orient, and then choosing Orient along path. You may need to use the rotation property to change the initial orientation (It may orient sideways for example, so you’d set rotation to 90 degrees).
    Aharon Rabinowitz
