Animated Bokeh ? – Using Particle World
Hi everyone!
I am trying to achieve this animated bokeh effect from the trailer for the film The Signal
https://youtu.be/gwgfeR2pMuE?t=107
So I started to follow this tutorial :
https://youtu.be/LJIW65ZW35kWhich has you using particle world and applying the Textured Disc Particle
The problem I am having is I cant seem to slow the animation down even with the velocity slider all the way to zero,
Secondly and most importantly, how can i adjust the direction of the animation? As you can see in the film trailer the bokeh is coming from left to right, I dont want it to live and die I want it to be on and come into frame.What would you suggest?
Thank you.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
