Activity › Forums › Adobe After Effects › animated backgrounds
  • animated backgrounds
    Posted by Den Newbie on June 10, 2006 at 11:58 am
    I am new to afetr effects 7, but when I try using the preset animated backgrounds, they will render but only for 5 seconds? in a 30 sec clip they render for 5 secs then timeline continues but background has stopped any movement! I have tried looking for any settings for effect duration but cannot find anything that helps!
    Sorry if this is a stupid question but it is doing my head in!
    Den Newbie replied 20 years, 3 months ago 3 Members · 5 Replies
  • Jeffrey
    June 11, 2006 at 12:08 pm
    try lowering your resolution settings to see if that changes anything.
  • Den Newbie
    June 11, 2006 at 2:24 pm
    I have dropped the resolution down to quarter and it still makes no difference! the animation still only renders for 5 seconds and then becomes still for the rest of the clip!
  • Jeffrey
    June 11, 2006 at 5:41 pm
    well I only have 6.5, so I am pretty much outta ideas…maybe try creating a comp with only the animated bkgnd. and see if that renders longer than 5 seconds and try to narrow down the problem.
  • Curtoid
    June 11, 2006 at 9:18 pm
    reveal the keyframes, and select them all, and then drag them out to as long as you want!
  • Den Newbie
    June 14, 2006 at 7:30 am
    Thanks for that last post, I found that opening up the graph editor in the timeline and then holding down mouse button to create a box and select all the animation points then enabled me to extend the duration of the animation, funny it is only in the background animations that I had this problem!
