Activity › Forums › Adobe After Effects › animate the amount of text on a path (After Effects)
  • Filip Vandueren
    November 15, 2022 at 6:08 pm
    Hey,
    add a slider to your Text Layer,
    the give the sourceText this expression:
    numChars = Math.floor(effect("Slider Control")("Slider").value);
    value.substr(0,numChars)+"\u200b";
    The slider now controls how many characters are visible.
    Adding the +”\u200b” (unicode character #200B = a zero width space), this makes the start and end characters line up with the same spacing as all the other characters along the path do.
    If you omit this, they will hug each other without any spacing.
  • Alessio Rattazzi
    November 15, 2022 at 7:20 pm
    Thank you very much Filip! Really clever idea 😎 it works perfectly!
    wish you a lovely evening
    Alessio
  • Alessio Rattazzi
    September 10, 2023 at 12:27 pm
    Hi Filip!
    Do you know how I could modify the expression so that the slider will let appear the entire words and not individual letters one after the other?
    kind regards and thank you in advance
    Alessio
  • Filip Vandueren
    September 11, 2023 at 11:21 am
    Hi Alessio,
    I would do it like this:
    words = value.split(/\W+/g);
    numWords = Math.floor(effect("Slider Control")("Slider").value);
    words.slice(0,numWords).join(" ")+" \u200b";
    split() makes the string an array of words, slice() limits the number of elements from the array, and join() converts it to a string again
    In this case I think I’d add that extra space before the \u200b.
  • Alessio Rattazzi
    September 16, 2023 at 11:51 am
    thanks a lot Maestro! Works perfectly
    wish you a lovely weekend
    Alessio
  • Alessio Rattazzi
    September 16, 2023 at 12:00 pm
    I just notice that the expression is working but is not showing special characters: like “ü” or “?”, any idea why instead of those there’s an empty space?
    thanks a lot again
    Alessio
  • Filip Vandueren
    September 16, 2023 at 12:05 pm
    Ah, sorry, I use the wrong split() parameter, this works:
    words = value.split(/\s+/g);
    \W is any character that’s “not a word character” and it’s too strict (it only matches a-z, 0-9),
    while \s is any “whitespace” character, which we need in this case.
