Activity Forums Adobe After Effects Animate text to fly off of an object
  • Animate text to fly off of an object
    Posted by Alex Siegel on January 22, 2015 at 3:11 pm
    I am trying to take footage of an object, such as a five dollar bill, and have the number 5 peel off of the object and fly or float forwards. The number five doesn’t have to disappear from the five dollar bill. How would I go about doing this in after effects?
    Alex Siegel replied 11 years, 8 months ago 2 Members · 6 Replies
  • John Cuevas
    January 22, 2015 at 4:38 pm
    First I would use a very large image—that way when your 5 moves towards the camera it doesn’t pixelate. In the comp, duplicate your 5 dollar bill and mask the “5” that you want to float away. I would probably enable 3D space and just animate the position & rotation. Also you might want to consider using some kind of distortion like bezier warp to make it peel off the bill, doesn’t need to be much.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Alex Siegel
    January 22, 2015 at 5:38 pm
    Thank you for your help. I was able to get what looked like the shape of the 5 to fly up but there is no fill to the mask. What could I have done wrong?
  • John Cuevas
    January 22, 2015 at 7:25 pm
    Use the 3rd to last icon above to post a screen grab of your “5” layer, with masks & effects and anything keyframed twirled opened. After you upload the screen grab, click on it and copy the embed code into your post.
    Thinkck.com
  • Alex Siegel
    January 22, 2015 at 7:38 pm
    Here are two images of my project. I created a mask of the number 1 on the dollar bill by using the pen tool. Then I was able to animate the mask to fly up. However, the mask has no fill so when the red dots go away its invisible. I want to make it look like the number 1 is flying up.
  • John Cuevas
    January 23, 2015 at 4:03 pm
    I can’t see what effects, transformations you made. Press “u” before taking your screen shot, please.
    Thinkck.com
  • Alex Siegel
    January 23, 2015 at 4:14 pm
    I actually just figured it out. I used the parallax effect. So I separated the photos into layers and made the numbers their own layer, brought them into after effects, created a camera layer, turned each photo layer into 3d and then animated the numbers. Thanks anyways for your help!
