Activity › Forums › Adobe Premiere Pro › animate text object to a path
  • animate text object to a path
    Posted by Pete Michaels on April 7, 2007 at 3:55 pm
    I want to animate an object (basically a period and some text) along a path (drawn with pen tool in Photoshop) which represents the outline of a racetrack. So the end result being as the video (onboard footage) plays, the dot&text move along the path, showing where the car is on the track. (obviously the keyframes are put in manually)
    Is this possible in Premiere? Or is AfterEffects/a plugin needed?
    Any help would be much appreciated.
    P.
    Vince Becquiot replied 19 years, 5 months ago 2 Members · 1 Reply
  • Vince Becquiot
    April 7, 2007 at 6:47 pm
    That’s going to be an After Effects project, since Premiere doesn’t support masks. In After Effects, simply create a mask, then copy the position keyframes to the object you want to animate; you may also have to check thr orient to path option, that will depending on the version you are using.
    Vince
