Activity Forums Adobe Premiere Pro animate stills in Premiere Pro CS6
  • animate stills in Premiere Pro CS6
    Posted by Julian Semilian on July 19, 2012 at 11:54 pm
    Hello,
    I hope this finds you well. I tried to animate a still by using the turbulent effect. I did all the right things, I hope, key-gramed the start frame of the still, then parked on the last frame and changed the settings of the effect. The effect distorted close to what I was looking for but the image did not animate, maintaining the same level of distortion from start to end.
    Any suggestions?
    Many thanks.
    All the best,
    Julian
    Julian Semilian replied 14 years, 1 month ago 2 Members · 2 Replies
  • Norman Greenwood
    August 13, 2012 at 7:26 pm
    I think this must be a keyframe/evolution mishap. Evolution will be the part of the effect that will cause the animation. Be sure that you click the stopwatch next to evolution on your start frame. The move to your end frame and change the value of evolution. This will automatically create a second keyframe so that you have animation.
    A tip: You can also right-click on the keyframes in the Effects panel and choose Ease-in or Ease-out. This just makes a smooth start and end. Ease-in would be for your last keyframe, and Ease-out for your last. Weird logically, I know, but it’s how it is.
  • Julian Semilian
    August 13, 2012 at 8:49 pm
    many thanks!
