Activity › Forums › Adobe After Effects › Animate Shape path
  • Animate Shape path
    Posted by Matthew Beall on April 3, 2012 at 2:47 pm
    Can you animate the path of a shape layer?
    I want it to draw on, but I don’t see that option..
    I have to create mask splines and use the stroke effect, which is twice the work..
    Matthew Beall replied 14 years, 6 months ago 2 Members · 3 Replies
  • Matthew Beall
    April 3, 2012 at 3:26 pm
    I see I can copy a shape path to a mask path, so that helps a little..
  • Declan Smith
    April 3, 2012 at 9:56 pm
    On your shape, add a “Trim Paths” operator (1), then set end to 0% (2) and animate up to 100%. You can also play with the start and offset to get other effects.
    Declan Smith
    https://www.madpanic.tv
    After Effects CS5.5/ FCS3 / Canon 7D / Canon XL2 / Reason / Cubase
    “it’s either binary or it’s not”
  • Matthew Beall
    April 4, 2012 at 3:33 am
    Declan:
    Thank you!!
    That is great, basically an animated stroke reveal for shape paths!
    Yay!
