Activity › Forums › Maxon Cinema 4D › Animate points on a spline?
  • Animate points on a spline?
    Posted by Chris Arnold on May 8, 2008 at 5:47 pm
    So my question may be basic, and I hope there is an easy answer. Question is, can you animate the individual points on a spline over time to move? How do you do so?
    Then I want to add an extrude to it to create a rope in the end, which I have no trouble with. But how do you get the points to animate?
    Thanks guys.
    Chris Arnold replied 18 years, 4 months ago 3 Members · 3 Replies
  • Randy Johnson
    May 8, 2008 at 7:09 pm
    point level animation there is a botton by the key frame botton default is turned off.
    /randy
  • Cactus Dan
    May 10, 2008 at 1:54 pm
    Howdy,
    If you constrain the points to Null objects, you can then animate the Null objects to control the spline points. This will give you more control over the animation of the spline, because you then have access to the Null objects’ Fcurves.
    My CD Constraints plugin includes a CD Points Constraint which makes it easy to setup:
    https://www.cactus3d.com/CDPointsConstraint.mov
    Adios,
    Cactus Dan
    Cinema 4D R10 XL Bundle, BodyPaint, Dynamics
    http://www.cactus3d.com
    http://www.cactus3d.com/Plugins.html
  • Chris Arnold
    May 12, 2008 at 1:18 pm
    I appreciate the help, the plugins you have on that sit look really useful!
    Cheers,
