Activity Forums Adobe After Effects Animate Layer Sorting
  • Animate Layer Sorting
    Posted by Randy Illum on March 12, 2011 at 6:26 pm
    Hello Everyone,
    In after effects I am trying to animate the sorting of layers. So when I change the position of a layer(ex one layer being moved above the other) in after effects it will record the change as part of the animation, at the selected time in the animation. I have 22 layers and would like to record each layer being moved to the top in one second intervals.
    Randy Illum replied 15 years, 6 months ago 3 Members · 4 Replies
  • Erik Waluska
    March 13, 2011 at 12:56 am
    I’m not totally sure I follow what you’re trying to accomplish but check out AEScripts.com, they have a ton of scripts for sorting, moving, abusing layers in various ways.
  • Randy Illum
    March 13, 2011 at 7:58 pm
    I have a script all ready that will randomly rearrange the layers what I am trying to do is:
    1. Have a layer arrangement
    2. Rearrange the layers (the layers have a low opacity so when the layers are rearranged it looks different) because the layers 100% overlap
    3. Record the layer rearrangement in the animation
    4. Rearrange the layers
    5. Record the new layer arrangement
    6. Repeat…
    Does this make more sense?
  • Tudor “ted” jelescu
    March 13, 2011 at 10:10 pm
    If I understand correctly you are trying to animate the layer order- I do not think AE does that. My way of achieving what I think you’re after would be to create several comps with different layer orders (one comp per combination) and then either render them out and use a editing app like Premiere or FCP to cut the 1sec segments from each combination and mix them, or do basically the same thing in AE but end up with a ton of precomps trimmed to one sec.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Randy Illum
    March 13, 2011 at 10:25 pm
    Ted,
    Thanks for your help. Not the answer I was hoping for, but going to do what you suggested and use Premiere to create the animation.
    -Randy
