Activity Forums Adobe After Effects Animate between keyframes?
  • Animate between keyframes?
    Posted by Dinci Kodek on February 3, 2018 at 11:16 pm
    I want to make a dynamic controller that needs to skip keyframes sometimes. For example. Using expressions, is there a way to animate an object’s keyframe 1 to keyframe 3 and skip keyframe 2 all together?
    Cassius Marques replied 8 years, 7 months ago 2 Members · 4 Replies
  • Dinci Kodek
    February 4, 2018 at 10:20 pm
    I have a Face made out of shapes. I use paths to morph the face from facing front ( keyframe 1 ) to facing left ( keyframe 2 ), than I have the face morphing to the right side ( keyframe 3 ). Is there anyway I can have some how make it so that the paths morph from keyframe 1 directly to keyframe 3 ignoring keyframe 2.
  • Cassius Marques
    February 5, 2018 at 5:22 pm
    Why not start with keyframe 3, go to 1 and then go to two? Now animate in your final comp using time remmap. That’s how you should do it.
    Cassius Marques
    http://www.zapfilmes.com
  • Dinci Kodek
    February 6, 2018 at 3:46 pm
    I’m terribly sorry, but I didn’t explain things well enough.
    There is multiple warps. So sometimes I need to go from key frame 1 to keyframe 10 and somehow skip keys from 2 to 9, etc etc. Is there just some way to get the value of a path’s keyframe and merge it to a different keyframe. Get and average of the 2 in away.
  • Cassius Marques
    February 6, 2018 at 6:24 pm
    Nope, there is no pose morph function for After Effects. Specially for mask animation.
    Cassius Marques
