Activity Forums Adobe After Effects Expressions Animate Between 2 Slider Values Help
  • Animate Between 2 Slider Values Help
    Posted by Sammy Rudkin on August 28, 2024 at 1:27 pm
    Hello!
    Hoping someone can help me out with this.
    I have 2 static Slider values and I’m looking for a way to animate from 0 > Slider 1 > Slider 2 (diagram attached)
    Not sure what the best way of doing this is when there are 3 values, as I can’t seem to get the Linear function to work for this. Wondering if there’s some combination of If Else with two different Linear functions to separate between A-B and B-C.
    Many thanks in advance!
    Yoan Boisjoli replied 1 year, 12 months ago 2 Members · 2 Replies
  • Sammy Rudkin
    August 28, 2024 at 1:34 pm
    Since posting this, I have put together an expression that works for what I need it for!
    I have a control slider that animates from 0 – 1 then 1 – 2. This slider has the following expression:
    anim = value;
    startval = thisComp.layer(“CONTROLS”).effect(“START”)(“Slider”);
    endval = thisComp.layer(“CONTROLS”).effect(“END”)(“Slider”);
    if (anim<1) {linear(anim,0,1,0,startval)}
    else {linear(anim,1,2,startval,endval)}
    Still interested in case there’s a more efficient way of doing this, so open to ideas 🙂
  • Yoan Boisjoli
    September 5, 2024 at 3:37 pm
    Hi Sammy!
    I think something like this would work:
    anim = value;
    linear(anim, 0, 2, 0, endval)
    Although If you still want to preserve control over the “midpoint” value (B), you can adjust the scaling and leverage a remapping approach:
    anim = value;
    // Midpoint value (Slider 1)
    midval = (startval + endval) / 2;
    // Remap anim from 0-2 range to startval-midval-endval
    linear(anim, 0, 2, 0, endval);
