Activity Forums Maxon Cinema 4D animate an emboss?
  • animate an emboss?
    Posted by Adam Tracksler on February 10, 2010 at 7:44 pm
    I am making an animation of a piece of “paper” (right now a sweep nurbs rectangle along a spline path) plane that gets pressed in a gear (cogwheel spline that has extrude nurbs applied to it) and comes out on the other side embossed with the gear pattern in it.
    I’m not sure of I am explaining it right, but before the paper goes over the gear i want it flat, and after it goes over the gear, I want it embossed so that it has the “teethmarks” in it.
    Is there a way to do this?
    Thanks in advance, ad
    P.S. Have a Nice Day!
    Adam Tracksler replied 16 years, 7 months ago 2 Members · 2 Replies
  • Randy Johnson
    February 10, 2010 at 9:08 pm
    Depends on your detail level.
    Is it so deep that you need to actually model the impression or can you get away with animating a bump map or displacement?
    /Randy
  • Adam Tracksler
    February 10, 2010 at 11:57 pm
    i guess it could go either way… what would be better? er.. easier….
