Activity Forums Adobe After Effects animate a semi/RV turn path
  • animate a semi/RV turn path
    Posted by Rick Neely on January 11, 2023 at 1:47 pm
    Hey guys,
    bit rusty on AE and thought maybe you guys can direct me to a tutorial or link for a special request project.
    Need to build a simple 2D animation showing an RV or semi truck making left and right turns out of a very narrow roadway. I know how to do the bezel path/auto orient function applied to a car layer, but to properly show how the vehicle turns the corner (factoring in wheelbase length effect, sharp turn, offset; etc). Additionally, client wants to show similar affect if the RV/Truck was towing a car or motorbike behing it.
    Thinking this can be down with adjusting anchor points and maybe subcomping the rv for each different anchor point (front axle, rear axle, towing axle). But if there is a tutorial or other method you could recommend. I’d appreciate it. Thanks in advance.
    Rick
    David Eells replied 3 years, 8 months ago 2 Members · 1 Reply
