Activity › Forums › Adobe After Effects › Animate a layer using a line
  • Animate a layer using a line
    Posted by Thomas J. m on May 11, 2005 at 9:12 am
    Hello out there
    I need to some how make a line so that i can get my layer to follow that line, i remeber i have seen this in somekind of presentation. Does annybody now how to do it. Can i for an example get my layer to follow the a mask i have drawn.
    MVH
    Thomas J. Mikkelsen
    Denmark
    Filip Vandueren replied 21 years, 4 months ago 2 Members · 1 Reply
  • Filip Vandueren
    May 11, 2005 at 12:27 pm
    You can copy a mask and paste it to position keyframes. If you use that same mask as a stroke on another layer, you’ll have your effect.
    Also, you can move the layer first, and pick-whip it’s position to the position of the write-on point on another layer. That way a line will be drawn following the motion of the layer.
