Activity › Forums › Adobe After Effects › Andrew Kramer’s tutorial on Depth of Field for After Effects 7
Posted by Cow_fan on June 30, 2006 at 2:04 amI tried the tutorial on
Andrew Kramer replied 20 years, 2 months ago 2 Members · 1 Reply -
1 Reply
Andrew Kramer
June 30, 2006 at 2:24 amYou need to “precompose” so the Lens Blur effects sees the “flattened” version of the gradient. If you don’t precompose the Lens Blur sees the layer color without the gradient effect.
The eye is essentially the on off switch however the data from a layer that isn’t visible is still available to other layers through effects in order to sample the values from the layer without actually seeing the layer.
So in the case of the Lens blur effect, the lens blur needs to use the gradient to figure out where the focal point is, but the visual need of the gradient isn’t needed.
Andrew
