and an HD monitor and the PVM 14″…
ohhh, the humanity…
i read earlier that it’s possible to get 2 PVMs for less than 4k… from what i found, one PVM 14″ is about $1500 then the HD card is another $1500. so that’s $3k… is there something i’m missing on the 2-PVM’s for less than 4k? is there an HD downconvert setting that is usable for CC?
i will be posting a doc in DVCProHD (my first HD project), and need a monitor for HD… but there’s a good chance i will be going out of house for a final transfer/color correction. if $ were no object, it wouldn’t be an issue, but for now that’s not the case.
so i guess the question is: is there a decent (relatively) inexpensive HD monitor out there? maybe a computer monitor with DVI or HDMI? — until i can afford a PVM?
as always thank you for the help…
e3
e. eric johnson iii
eric@lillcreates.com
lill creates: founder/executive producer
Water Channel: producer/virtual set operator
