Activity Forums Adobe After Effects anchoring point of text?
  • anchoring point of text?
    Posted by David Del on July 8, 2008 at 12:25 am
    I want to move the anchor point for a piece of text to the middle of the “letter” so when it spins, it spins around the center. Not quite getting it, any suggestions?
    David Del replied 18 years, 2 months ago 3 Members · 3 Replies
  • Peter O’connell
    July 8, 2008 at 4:45 am
    Hi, click y first.
    Pete
    peteoconnell.com
  • Wieger De leur
    July 8, 2008 at 9:04 am
    Hi David,
    – twirl open your text layer;
    – click on the triangle next to ‘animate’, which you can find to the right of ‘text’ in the time line;
    – select ‘anchor point’ from the popup menu;
    – now you can adjust the anchor point;
    If you animate something like rotation after this (make sure you don’t add it to the same animator), it uses the new anchor point.
  • David Del
    July 8, 2008 at 2:18 pm
    I used the pan behind tool, but needed to be on the anchor point for it to work. Thanks.
