Activity Forums Adobe After Effects Anchor points from a shape path following animated position from null objects
  • Anchor points from a shape path following animated position from null objects
    Posted by Philipe Karlsson on February 3, 2012 at 12:25 pm
    Im looking for a way of connecting anchor points from a shape path to let them follow a separate motion.
    example: an shape path with 3 anchor points, each anchor point following a animated position of a null.
    is this possible?
    Sincerely,
    Paul Roper replied 14 years, 7 months ago 2 Members · 1 Reply
  • Paul Roper
    February 3, 2012 at 5:22 pm
    The short answer (I’ve tried to do something very similar) is no. It’s a feature that many of us have requested…who knows if it will ever materialise.
    Feel free to send a feature request to Adobe:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    It IS, however, possible using some fairly complex scripting…but unless you’re going to be repeatedly using a similar animation many times over the coming months, you’d probably be better off just animating the shape manually.
