Activity Forums Adobe After Effects Anchor Point help
  • Anchor Point help
    Posted by Fabiano Peres on July 6, 2006 at 11:21 am
    Hi there,
    When I click on a specific place on my monitor window to type some text, the anchor point always starts on a diferent place, sometimes even offscreen.
    Then I correct it and it’s ok, but now I’m trying to use the Write-on effect and I have the same error, and on this one it doesn’t work if I correct it’s inicial position, the rest of them are still wrong, even if I select all of keyframes…
    What do I do?
    Thanks for the attention.
    Fabiano Peres replied 20 years, 1 month ago 2 Members · 3 Replies
  • Steve Roberts
    July 6, 2006 at 12:48 pm
    It sounds like you’re working in 3D space. If so, try switching to the front camera, type your text, then switch to the regular camera for more positioning.
    Let us know …
  • Fabiano Peres
    July 6, 2006 at 7:10 pm
    No, it’s not the 3D space, there is nothing 3D on my comp. I start a new comp click the text tool and click on the monitor window, and it’s always bad positioned…
    HELP ME PLEASE.
  • Fabiano Peres
    July 6, 2006 at 9:00 pm
    OK, let me try to explain…
    The problem is not with the write-on efect, the problem is that when I paste the mask keyframes into write-on’s position property, they are never at the place they should be. They are on a different location of the screen, as a ghost on a bad TV image… I have already tried to select all of them and reposition, but it doesn’t work, I have to reposition them one by one.
