Activity Forums Adobe After Effects Anchor point changes when Duplicate layer.
  • Anchor point changes when Duplicate layer.
    Posted by Kurisuta Vd wilk on February 3, 2012 at 12:10 pm
    Hey!
    i have a comp : 6400 x 720
    a shape layer of a square
    I pan behind the anchor point to the left of the square ( so i can rotate it from out that point)
    then i Duplicate the shape layer
    And the Anchor point of the new layer is in the middle of the comp.
    When you duplicate a layer, it should duplicate it exactly, right?
    Or am i missing a point here …
    No knowledge is a Statement
    Angie Taylor replied 14 years, 7 months ago 2 Members · 1 Reply
  • Angie Taylor
    February 3, 2012 at 4:43 pm
    Hi there,
    Shape layers are strange creatures, but endearing all the same! 😉
    You may not have noticed that with Shape Layers there are 2 sets of Transform properties. The Pan Behind tool will move the Anchor Point of the layer but it sounds like you want to move the Anchor Point of the shape. to do this, open the Layer, go into Contents > Rectanagle 1 > Transform: Rectangle 1 > Anchor Point. Use these controls to adjust the AP and you should be OK.
    Hope this helps!
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
