Activity Forums Apple Final Cut Pro Legacy anamorphic squeeze HVX200
  • anamorphic squeeze HVX200
    Posted by Andrew Paul bowser on November 13, 2007 at 2:07 pm
    I shot some footage on tape, on the HVX200.
    My camera and record settings were anamorphic squeeze and 480i 24p
    In FCP everything is fine, as soon as I export a quicktime- the image is no longer squeezed- but stretched. Even when I click “letterbox to preserve aspect ratio”
    What is the deal?
    -Andrew
    Tom Matthies replied 18 years, 10 months ago 3 Members · 2 Replies
  • Rafael Amador
    November 13, 2007 at 3:08 pm
    So you recorded DVCPro25, 16×9, right?
    Qt display your footage as square pixels. You can change the display aspect ratio. In Properties>Video track>Visual setting> Ucheck Preserve aspect ratio>
    Then you must increase the with, instead of 720 you must set 800 (not 100% sure, I’m a PALre)>Intro and by now your picture should be Annamorphic.
    In PAL-land we set 1024 instead of 720, but the pixels are different.
    rafael
  • Tom Matthies
    November 13, 2007 at 3:11 pm
    I believe that 853×480 will do the trick for you.
    Tom
