Activity Forums Apple Final Cut Pro Legacy Anamorphic output for idvd – retaining 16:9 format
  • Anamorphic output for idvd – retaining 16:9 format
    Posted by Souljah44 on June 8, 2007 at 6:44 pm
    I’m working on a project that i did in a DV NTSC anamorphic timeline FCP 5.1.2. Each time I’ve tried to export a quicktime movie a (fat file) it changes the aspect ratio to letter box. Now, i have been able to export using certain settings in Compressor (DV NTSC Anamorphic and changing the pixel aspect ratio) – this has given me an anamorphic quicktime, but then when I bring it into idvd, it is, again, changing the project to letter box. Anyone know how I can preserve the anamorphic look when exporting for iDVD?
    thansk.
    Nothing to say too much editing to do.
    Miodrag Ristic replied 19 years, 3 months ago 5 Members · 6 Replies
  • Tom Wolsky
    June 8, 2007 at 6:52 pm
    See if this helps https://www.fcpbook.com/Video9.html
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Souljah44
    June 8, 2007 at 7:18 pm
    Thanks Tom,
    Is anamorphic a problem in DVD Studio Pro or Toast as well?
  • Tom Wolsky
    June 8, 2007 at 7:40 pm
    Not for DVDSP. I can’t speak for Toast. I only use it for data discs.
    All the best,
    Tom
  • Joe Gill
    June 8, 2007 at 8:18 pm
    For what it’s worth, anamorphisizer is wonderful, but DVDSP is a better solution instead of a patch.
  • David Roth weiss
    June 8, 2007 at 10:10 pm
    [Tom Wolsky] “I can’t speak for Toast.”
    Toast will do anamorphic, but not a great choice for DVDs. Compressor and DVDSP are much more dependable.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Miodrag Ristic
    June 9, 2007 at 8:52 am
    I had to do it a couple of months ago and found that iDVD doesn’t recognise
    a flag for anamorphic.
    Luckily there is a little utility where you drop your exported QT and voila –
    it stays 16:9. It’s called Anamorphisizer.
    It works and it’s very simple, just follow onscreen instructions.
    You can downloaded it for free here:
    https://homepage.mac.com/sith33/FileSharing34.html
    Cheers
    Mick
