Activity › Forums › Blackmagic Design › Anamorphic Footage Monitoring FCP
  • Anamorphic Footage Monitoring FCP
    Posted by James Herring — account refuses cow mail on September 15, 2005 at 2:49 am
    Hello,
    I am using the Decklink SP card for video out from Final Cut Pro 5 HD. I can’t view the footage in 16:9 wide frame mode on my monitor because I don’t have that option on my external monitor. Is there a way to view SD footage in the leterboxed mode using Blackmagic software.
    These options are available in the software setup for HD footage, but I can’t figure out how to do the same with SD footage.
    My other question is… If I upgrade to the Blackmagic HD cards, will I still be able to monitor SD content?
    James –
    Create Something Wonderful
    Luke Maslen replied 21 years ago 3 Members · 3 Replies
  • Kaspar Kallas
    September 15, 2005 at 6:20 am
    1. In Fcp change clip aspect ratio (motion->distort->aspect ratio) to -33 so you would be using 4:3 with black bars on top and bottom. This will be RT, so will not need to render anything. When laying back to tape select all clips ctrl+clik->remove attributes and select distort -> now you will have anamorphic picture again.
    2. Yes HD cards support SD as well
    -Kaspar
  • James Herring — account refuses cow mail
    September 15, 2005 at 4:42 pm
    Thanks Kasper,
    I’ll give this a try, sounds good.
    James –
  • Luke Maslen
    September 16, 2005 at 6:25 am
    Great reply Kaspar!
    Short and to the point 🙂
    Thanks for helping out.
    Regards,
    Luke Maslen
    Blackmagic Design
