Activity Forums Apple Final Cut Pro Legacy Anamorphic DV
  • Posted by Meeroo Sareew on September 20, 2006 at 11:50 am
    I have some problem understanding this…
    As I understand, widescreen DV(PAL) is resolution 720×576, but with different pixel shape than the 4:3 mode.
    So, if somebody is shooting with DV camera in widescreen mode what is he really getting? Is his picture wider or is just his vertical size smaller?
    When I edit that footage in FCP in widescreen (DV PAL anamorphic) mode and than make widescreen DVD, I guess it will look normal if DVD read it as anamorphic. But what happened if I have to send it to TV station? What settings should I use to export it to tape (e.g. Beta SP) and how will the footage be displayed on TV?
    Tnx
    M
    Mac: Quad 2.5 + OS 10.4.6 + Final Cut Studio HD + Multibridge Extreme + Sony DVW-M2000P
    PC: Xeon 3.00GHz + Premiere Pro 1.5 + Decklink Extreme + Sony UVW-1800p + Sony HVR-M10E
    Daniel Serrano replied 20 years ago 6 Members · 8 Replies
  • 8 Replies
  • Mactrix
    September 20, 2006 at 1:54 pm
    You have to make a note on your master tape that it is 16:9.
    The TV station will notice that it’s anamorphic 16:9 and they
    will broadcast it with a special coding. The TV will recognize
    it and add letterbox to a 4:3 device or deskew for 16:9 …
  • Rafael Amador
    September 20, 2006 at 4:06 pm
    Truth. Many TV stations do not accept annamorphic, because they know they risk to broadcat it unproperly. So to avoid problems they preffer you just to stick your beautyful 16×9 on top of a 4×3 black.
    Salud,
    rafael
  • Martin Baker
    September 20, 2006 at 6:32 pm
    Depends where you are. Here in the UK anamorphic delivery for broadcast has been the standard for around the last 10 years and a letterboxed version would be rejected.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! DH_RetroTV and DH_Dream plug-ins for FCP
    NEW! Hot Tips video podcast for FCP
  • Meeroo Sareew
    September 21, 2006 at 8:07 am
    [Dave LaRonde] “Neither of the above: he loses no vertical size, but when the picture is played back on something that is not set for anamorphic video, the picture looks like it’s squeezed horizontally.”
    ah yes… I guess I wasn’t clear enough about this. What I ment is: what is the difference between filming in 4:3 and 16:9 mode on DV cameras? Since there’s no lense changing I’m wondering how it’s done?
  • Tom Wolsky
    September 21, 2006 at 8:30 am
    In most DV cameras the image is squeezed horizontally to make it anamorphic. The image is still 4:3, just squeezed. You have to tell the application it’s anamorphic to for it digitally spread the horizontal resolution.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Daniel Serrano
    September 22, 2006 at 3:21 am
    I’m just doing a 16:9 tv program but I give to the tv people in 4:3 letterbox…
    they told us that it was easier to broadcast because not too many people have widescreen TV sets…
    well I see a lot of them around…
    Mexico is a little behind in some parts, and the TV station well it not state of the art, yet…
    betcha TELEVISA and TV AZTECA, they sure can broadcast in 4:3 and in 16:9…
    Hello from Mexico….
  • Rafael Amador
    September 23, 2006 at 5:12 am
    Hola Daniel,
    I don’t know much about the new TV distribution systems (Cable, satelites, etc) but with PAL and NTSC, if you brodcast a 16×9 programm, only the people that have TV sets where you can select the aspect (4×3,16×9) could see properly the image. The people who can only watch in 4×3 would see the image distorted. So the TV stations must broadcast programms tha has been already letterboxed when formating the film, or have to letterboxe in the studio, right before broadcasting.
    In my country, like in Mexico, they just prefers letterboxed, because like that don’t risk to forget the right set-up when airing the film.
    Salud,
    Rafael
  • Daniel Serrano
    September 23, 2006 at 10:26 am
    yes, indeed Rafael, that was the same thing we came up with, when deciding about the letterbox option, it was the best thing to do, so more people see it the way we intended, even if it was letterboxed…
    saludos
    Hello from Mexico….
