Activity › Forums › Apple Final Cut Pro Legacy › anamorphic DV video to QT
  • anamorphic DV video to QT
    Posted by Mark023 on January 25, 2007 at 5:29 pm
    I done this a hundred times with no problem. I just finished editing some widescreen DV video with FCP set to DVanamorphic. I then exported the finished video to Quicktime. It came out stretched. So I tried setting the QT settings to DVanamorphic and it came out the same. I want to end up with a letterbox Quicktime file. Can anyone tell me what I’m doing wrong? Thank you.
    Mark023 replied 19 years, 8 months ago 2 Members · 2 Replies
  • 13 Create COW Profile Image
    13
    January 25, 2007 at 6:10 pm
    Export quicktime movie and make sure it is set on use current settings, this will use the same settings as your timeline.
  • Mark023
    January 25, 2007 at 6:26 pm
    Thank you zrb123. I usually never touch that setting. I did this time (for no apparent reason). Much appreciated.
