Activity Forums Apple Final Cut Pro Legacy Anamorphic distortion in FCP
  • Anamorphic distortion in FCP
    Posted by James Henry on May 14, 2009 at 8:57 am
    Hi there,
    I’ve got an anamorphic quicktime file that I’d like to generate a 4×3 letter-boxed quicktime file from for web usage. Normally I’d just drag this file to a 4×3 timeline in final cut pro and it would resize perfectly, however I’ve done this and although the file is letter-boxed there is some slight vertical stretching going on i.e. long faces.
    The distortion box is set to -33.3% at the moment – I was just wondering if there was another field value that would correct this… At the moment I’m trying it by eye and I’ve settled on -42%, but obviously I want to make sure it’s right for the client (and not just say I did it by eye if they ask!!!)
    Any help would be greatly appreciated!
    James
    Rafael Amador replied 17 years, 4 months ago 2 Members · 3 Replies
  • Rafael Amador
    May 14, 2009 at 9:15 am
    Hi James,
    Don’t touch the distorsion.
    Have a look in the Browser window> Pixels Aspect.
    rafael
    http://www.nagavideo.com
  • James Henry
    May 14, 2009 at 9:22 am
    Hi Rafael,
    thanks for your response, I’ve had a quick look at the pixel ratio and bout sources are set to PAL – CCIR 601 which I believe is correct?
  • Rafael Amador
    May 14, 2009 at 9:28 am
    Hi James,
    Sorry I’ve read too fast.
    Check Anamorphic in the Browser “Anamorphic” column.
    rafael
