Activity Forums Adobe After Effects Anamorphic composition and render
  • Anamorphic composition and render
    Posted by George Ovcinikov on April 13, 2013 at 12:07 pm
    Hi Guys,
    I have been scouring the web for this but unfortunately did not seem to get a good understanding so I have to resort to posting my question and will be extremely thankful if you could help out.
    Basically, I have to deliver a video for broadcast. Here are their format requirements:
    output format: Quicktime.mov IMX50 anamoprhic, Pal, Video encode: D-10/ IMX, Audio Encode: PCM
    frame: rate: 25
    frame rate mode: Progressive
    resize: Active Picture: w- 720 h- 576, Frame Size: w- 720 h-608
    Encode profile 50mbps Mpeg2 4:2:2@ML
    Audio Profile GOP Structure I-Picture Only
    This is my first time of delivering for broadcast and im panicking.
    My composition settings are: HDTV 1920×1080, 25fps, Square Pixels
    I am able to find an IMX50 codec, I think I will also be able to identify correct settings for the audio.
    What I don’t understand is how to export a correct anamorphic 16:9, I don’t even know what steps to take in order to achieve this.
    I someone could please take a minute and explain to me what render settings to set up in oder to export the video to the requirements above. Do I need to fiddle with the composition settings or can it be done in the render process?
    Please help me out if you have a spare minute, I will be extremely grateful.
    George
    Tudor “ted” jelescu replied 13 years, 5 months ago 2 Members · 3 Replies
  • Tudor “ted” jelescu
    April 13, 2013 at 8:22 pm
    Yeah, weird standard I know. Here’s a thread that may help:
    https://forums.creativecow.net/thread/232/870
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • George Ovcinikov
    April 14, 2013 at 10:47 am
    Thank you for your reply,
    Could you please have a look at the attached pictures whether my composition settings are correct (picure 1).
    The composition that I get is 4:3, should I render it as it is (picture 2) or scale it so it is widescreen (picture 3).
    I do not fully understand what anamorphic is so could you please advise which one of these will be correct according to the resolution delivery requirements mentioned earlier. Which one of these is the correct 720×576 anamorphic?
    Thank you
    April 15, 2013 at 7:49 am
    No re-scaling. You want your image to be squeezed because it will be stretched back in playback.
    Study a bit about anamorphic – it’s something you should know:
    https://en.wikipedia.org/wiki/Anamorphic_format
    Tudor “Ted” Jelescu
    Senior VFX Artist
