  • Posted by Jian on April 2, 2005 at 10:56 am
    My short film was short on a XL-2, in 16×9 aspect ratio.
    When I digitized them into the computer, the setting was DV PAL (720×576) and the Anamorphic 16:9 box was checked.
    Is this the right setting? Suppose I have the same sequence settings?
    When I watch my masters/source tapes playback on tv, the picture is squeezed to 4:3. How do I make sure that the final output on to DV is not squeezed?
    Thanks.
    Jian
    Jerry Hofmann replied 21 years, 6 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    April 2, 2005 at 12:50 pm
    After you’ve edited the anamorphic footage, create a new sequence that isn’t anamorphic, and simply drag the 16:9 sequence to it. Render it. Then it will become letterboxed on a 4:3 set playing back from tape.
    If you create a DVD with this footage you don’t have to do this however, just turn on the 16:9 setting in Compressor or DVD SP 3, select whether or not you want it letterboxed or “pan and scanned”, and automatically it will be letterboxed on a TV set that’s 4:3, and will also fill the screen on a 16:9 set.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
