Activity Forums Apple Final Cut Pro Legacy analyzing dv audio
  • analyzing dv audio
    Posted by Andrei Bocharnikov on August 31, 2006 at 5:53 am
    i cant figure out what is going on with my FCP 5.1… after capture of the tape it hangs on the “Analyzing DV Audio. Validating Audio Data” screen for about 30 minutes. System is not frozen because i see that mac writting something to my external hard disk, which i settled as capture scratch.
    Andrew
    Andrei Bocharnikov replied 17 years, 3 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    August 31, 2006 at 11:11 am
    [Andrew B.] ” after capture of the tape it hangs on the “Analyzing DV Audio. Validating Audio Data” screen for about 30 minutes”
    Do you use “Capture Now” and capture an entire tape at once?
    What happens if you mark IN & OUT points (for one or several smaller clips), save those marked clips, then use “Batch Capture”?
    I avoid “Capture Now.”
  • Greg Thrasher
    June 6, 2009 at 5:52 pm
    When it gets stuck, should I wait it out or stop and cancel?
  • Andrei Bocharnikov
    June 8, 2009 at 8:25 pm
    Greg, sorry it was so long ago that I already do not remember what solution i found out. Now I am already on FCP 6 and do not capture from a tape.
    MacPro Dual Quad 2.8 GHz, 4 GB DDR2 SDRAM, Leopard 10.5.6, QT 7.5.5, FCS2
