Activity › Forums › Blackmagic Design › Analogue audio into DeckLink Extreme for VO recording
Posted by Rupert Watson on August 2, 2005 at 10:53 pmCan anyone spell out the steps for successfully getting an analogue audio signal into FCP 5 from a Mic via DeckLink Extreme? Seems it doesn’t “just work”.
Thanks in advance
Lars Petter ommundsen replied 21 years ago 5 Members · 4 Replies -
Jason Levy
August 3, 2005 at 2:14 amI think the trick may be that you still have to feed the video input a signal whether you record it or not for it to work .. I seem to recall reading that somewhere. haven’t tried it.
Jason
Rob Alexander
August 3, 2005 at 8:32 amtry using the voice over tool to an empty timeline then copy and paste your vo into your sequence. Works for me
Luke Maslen
August 4, 2005 at 2:24 amHi Rupert,
The answer to this is buried in the DeckLink Readme file.
To enable Voice Over Tool, you need to follow a similar procedure to DV, and use the following settings. Use the Displays menu (page 13 of the DeckLink Macintosh v2 manual) to set the DeckLink desktop to the same format as the video source, eg. NTSC 720 x 486. Next in the View menu of Final Cut Pro HD, set External Video to “Off”. When finished with the Voice Over Tool, set External Video to “All Frames” to use the broadcast monitor.
Regards,
Luke Maslen
Blackmagic Design -
September 21, 2005 at 2:37 pmI am able to use the voice over tool with SDI and embedded audio but have not been able to use it with analoge? I see in log&capture that I have audio in on the analoge inputs but when I go to voice over tool analoge doesn
