Activity Forums AJA Video Systems Analog video/audio Kona 3 and Aja IO (not IO HD)
  • Analog video/audio Kona 3 and Aja IO (not IO HD)
    Posted by Mike on August 29, 2007 at 9:10 pm
    I just bought a Kona 3 card and it’s awesome! However, I would still like to use my IO for analog import/export and to feed analog audio to my mixer. Maybe even use the IO as an audio converter.
    Here’s what I have:
    Kona 3 w/K3-box, Mackie 1202, AJA IO, and HD link feeding my Apple 23 inch monitor.
    How should I hook up my AJA IO to the K3-box so I can digitize analog video/audio and view analog video on the monitor using the HD Link. Make sense?
    I tried a few combos and was unsuccessful. Is it even possible to use the IO with Kona 3? Any suggestions would be appreciated.
    Mike
    Mike replied 18 years, 8 months ago 2 Members · 2 Replies
  • Bob Zelin
    August 29, 2007 at 10:07 pm
    you put your analog video into the AJA I/O. You launch the AJA I/O Pro Control Panel, and select your input (composite or component via the INPUT tab). Now, take one BNC cable, and come out of the SDI output of the AJA I/O, and go into the HD Input 1 of your Kona 3. Make sure that Input 1 is selected in your Kona Control Panel. That’s it. You are now using the I/O to convert your analog source to SDI, and the SDI source now goes into your Kona 3. I do this all day long. You can use this method to UPCONVERT to HD as well.
    Bob Zelin
  • Mike
    August 30, 2007 at 3:35 pm
    Thanks Bob! I’ll try your method later today. I’ll keep you posted. Thanks again!
    Mike
    You don’t have a chance unless you take one.
