Activity › Forums › Blackmagic Design › Analog to SDI Mini Converter problem
  • Analog to SDI Mini Converter problem
    Posted by Elias Caro on November 29, 2011 at 6:21 pm
    Greetings to the community, I have a problem with the system conversion Analog to SDI Mini Converter Blackmagic, I have tried everything and every possible combination and I can not make out the SDI signal, I tested from composite video to component video and also for s-video, but nothing at all, the pin configuration is not, even if I connect to a recorder AG-HMR10 shows me the message of SDI input error (other format) but if I connect to other systems mini-converter takes the signal to me, for days I’m trying to configure it but no solution. greatly appreciate the assistance provided.
    Elias Caro replied 14 years, 10 months ago 2 Members · 2 Replies
  • Justin Strauber
    November 30, 2011 at 10:25 am
    You will most likely not be able to use that combination of devices. The recorder you’re using only records in HD formats (720/1080), and will not accept an SD input, to my knowledge.
    You would need something like an UpDownCross converter, or FS1 in order to use the analog to SDI adapter.
  • Elias Caro
    November 30, 2011 at 4:22 pm
    I see, yesterday after posting the question I knew it was so when he started testing right through the DeckLink Studio,
    thing now that I recommend to upscale from 720×480 to 1080i, I know that is impossible because you purchase a LG DVD player has HDMI output and outputs the signal to 1080i, and so says the manual does an upscale image.
