Activity Forums AJA Video Systems Analog to SDI & AES for Kona 2
  • Analog to SDI & AES for Kona 2
    Posted by Scott Shucher on May 7, 2005 at 7:19 pm
    I am planning to abandon my CineWave shortly, and it looks like the K2 is going to be the way to go. The Decklink “Multibridge” looks cool, but I may not want to wait until late summer.
    I’ll still need to access beta SP footage regularly, so I guess my choices are adding A to D converters for video and audio, or getting a AJA IO/la and run it off the firewire bus. Can anyone weigh in on the “real-world” applications of converters versus an IOla playing nicely with the Kona2 on the same G5?
    Scott Shucher
    AppleCart Digital Video
    http://www.applecart.tv
    G5 2.5ghz DP, 2.5Gbyte RAM, FCP HD 4.5, OSX.3.7
    QT6.5.2, CW 4.7, Pro Analog BOB, Atto UL3D, Medea RTRX640, Huge MV 1.8Tbyte, Radeon 9800XT
    Walter Biscardi replied 21 years, 4 months ago 4 Members · 6 Replies
  • John Ladle
    May 7, 2005 at 7:26 pm
    IO works nicely and plays well with kona. the converters work too. depends what you personally like.
  • Walter Biscardi
    May 8, 2005 at 12:40 am
    Scott, you’re making the right choice moving from CineWave to the K2. I added an M-Audio Flying Cow A/D audio converter for the occassional analog audio I need to get into the K2. I run the output from my Mackie 1202 directly to the Flying Cow and that feeds AES to the K2. I also run the AES output from the K2 through the Flying Cow for playback in the suite. But from both AJA and other users I’ve heard the Io plays very nicely with the Kona 2.
    Just FYI, I run all my Beta tapes via my Sony J3/902 player deck which plays all formats of Beta via SDI so I can play out my BetaSP material via SDI directly in to the K2. I have to say, the BetaSP looks better coming down the SDI than it ever did via Component. It’s a player only, but it’s been a great investement for our company.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Tim Langston
    May 8, 2005 at 3:24 pm
    So what your saying is, use the IO as the A to D converter, edit using the Kona 2 then output back thru the IO? For Analog that is.
    Tim
    Tim Langston
    Cryin’ Out Loud Productions
    Fort Wayne, IN
    http://www.colproductions.com
  • Scott Shucher
    May 8, 2005 at 3:45 pm
    Hey Walter, It’s nice to see alot of the old CineWane(sic) community hanging out over here.
    Have you seen any audio/video sync issues going through the converters?
    Scott Shucher
  • John Ladle
    May 8, 2005 at 4:12 pm
    you do not have to use the IO to output. the kona 2 actually lays off analog, it is just the ingest that needs to be SDI–with dual link, there is not enough room on a PCI card to have anything else in the back of it other than the two HD/SDI. that will let you uprez SD analog if you set up the IO in front of the kona.
  • Walter Biscardi
    May 8, 2005 at 10:56 pm
    [Scott Shucher] “Have you seen any audio/video sync issues going through the converters?”
    Nope, everything seems to be pretty rock solid here. I run very short audio cables, just three feet between everything.
