Activity Forums Adobe Premiere Pro Analog Capturing thruogh DV cam
  • Analog Capturing thruogh DV cam
    Posted by Eyal Elbaz on April 28, 2006 at 11:25 am
    hi,
    i want to capture old videos from my vcr.
    i connected my vcr to my dv cam, and tried to capture it in premier.
    but when i capture in premier, premier makes my cam play the dv cassete
    and capture it instead of the analog source.
    if i eject the dv cassete premier won’t capture anything thaough i see in my cam the analog source.
    what can i do?
    thanks
    Eyal Elbaz replied 20 years, 4 months ago 3 Members · 3 Replies
  • Mike Velte
    April 28, 2006 at 11:47 am
    There is probably a camera menu setting like A/DV that will allow pass thru of your VCR signal. Camera may need to be in the Record mode as well.
  • Blast1
    May 2, 2006 at 8:33 pm
    The setting is in the Camcorder VCR menus, usually “A/V to DV out” in this case set to ON, don’t have a tape in the camcorder, it will take precedence if you use the device control, there is usually no device control with a analog VCR so you have to start the analog vcr manually then likewise start the capture in the computer manually.
  • Eyal Elbaz
    May 4, 2006 at 5:24 am
    thank you
