Activity Forums Web Design (WordPress, Joomla, etc.) An important feature in the HESTIA and SUKI WordPress themes
  • An important feature in the HESTIA and SUKI WordPress themes
    Posted by Ron Lindeboom on September 5, 2018 at 5:29 pm
    If you are serious about having a great looking WordPress blog or articles content engine, then you will want to pay special attention to the Hestia and SUKI themes.
    Why?
    Most themes if you add an image within the body of the text and want your text to wrap around the image but the point where you add the image is in a paragraph whose text is not very long (let’s say it only comes down halfway the length of your image), the theme’s engine will “push” the following paragraph or sub-header and any text that follows, down below the image leaving a large white space where your paragraph ends and the next one begins.
    Hestia and Suki are the only major themes we have found where that does not occur. Hestia and Suki will instead “draw up” the text that follows to wrap around your image, just as you would expect to happen in a desktop publishing program of a word processor. The dread huge white gaps are gone. (While OceanWP can also do the wrap, as can the Journal theme, I really do not like the look they generate — but you might.)
    To see how posts display check out this great theme comparison from JP at Learn Brizy Page Builder (even if you don’t use Brizy).
    Best regards,
    Ronald Lindeboom
    CEO, Creative COW LLC
    Creativity is a process wherein the student and the teacher are located in the same individual.
    Bret Williams replied 7 years, 11 months ago 2 Members · 3 Replies
