An “easy” way to deform videos? Vegas Pro 14
Hi there,
currently I try to add a video from mine on a moving screen.
For better understanding this is the video that I took. You can see the screen which I’m talking about. Start ~ 01:00 https://www.youtube.com/watch?v=-op_9cba8Qk
Now I want to get rid what they are showing on that screen and add my video.
What I did so far: I masked (negative) the complete screen and animated it. Now I “only” need to put my footage one layer below in vegas. The problem is that the screen hast a trapezial form. Therefore, I have to deform the clip make it fit into it.
However, if I use the video FX effect “deform” this is a… well sorry for my language… a pain in the a**. The masking was already a lot of work, but deforming the clip into there is nerve wrecking.
I was wondering if there is an easier way to do it. Is there maybe an option to “drag” and animate the corners of my footage? For example for the masking part I was able to drag & animate the cornerstones as needed.
Thank you in advance for any help.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
