Activity Forums Adobe After Effects An easy animation…I just cant figure it out
  • Christopher Grosso
    June 5, 2008 at 11:01 pm
    I thought that the best way to do this would be to create a path for the text to follow. So the path is straight across, then I would make it a “u” shape. I just don’t know how to animate that path from a straight line to a “U” shape.
    There is probably an easier way to do this. Again I am just looking to make a straight line of text bend down into a “u” shape
    Produce | Shoot | Edit
    Take Two Visual Media
    https://www.take2vm.com
  • Darby Edelen
    June 5, 2008 at 11:24 pm
    Create your mask on the text layer as a straight line, add a vertex at about the midpoint of the straight line. Set a keyframe on the mask path property, then move forward and move the middle vertex down, use the pen tool to create the bezier curve as you want it at this point. Then under the Text’s Path Options choose the mask you just animated as the Path.
    That should be it unless I’m misunderstanding.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
    June 6, 2008 at 3:12 am
    That’s it Thanks!!
