Activity › Forums › Apple Motion › amplitude of the audio on motion
Posted by Vjonuno on November 7, 2006 at 2:53 pmHello all,
is it possible to animate a parameter based on the amplitude of the audio on apple motion
thanx in advance.
vjonunoPeter Wiggins replied 19 years, 11 months ago 3 Members · 2 Replies -
Adolfo Rozenfeld
November 7, 2006 at 7:19 pmUnfortunately, Motion doesn’t currently have expressions or any other form of parameter linking. That is needed to do what you want. BUT… specialcase wrote an utility which converts After Effects position keyframe data to Motion position property. You could use After Effects’ Convert Audio to keyframes assitant, copy the resulting keyframes to the position property, and then use specialcase’s tool (you will have to copy and paste the position keyframes to the property you want).
To download it:
https://www.motionsmarts.com/downloads.htmlAdolfo Rozenfeld
Buenos Aires – Argentina
https://www.adolforozenfeld.com
adolfo(AT)adolforozenfeld.com -
Peter Wiggins
November 7, 2006 at 10:40 pmWell there is some good news…
You can write a plugin using FXFactory & Quartz composer that will take audio amplitude or even frequency and modulate a parameter.
Take a look at the cube I have on my homepage
https://www.peterwiggins.com/
Does exactly that, you can open the thing up in quicktime player etc.here is the bad news – although it will play in motion, when you render the timeline doesn’t move so there is no sound, so it doesn’t move.
sigh! almost there!
Peter
