Activity › Forums › Apple Final Cut Pro Legacy › Amount of time it takes to compress w/compressor
  • Amount of time it takes to compress w/compressor
    Posted by Michael Lynch on January 19, 2007 at 6:15 pm
    I’ve been getting about a 5:1 time ratio for compressing AV from Quicktime to m2v and ac3 via compressor to make files for use in DVDSP. Is this a common duration? I sometimes have 60 minute programs, and am looking at a 5 hour compression session. Seems ridiculous to me, so I thought maybe I’ve got some messed up settings or something.
    Any feedback would be appreciated.
    Mike
    G5 – 2GIG DUAL – 2GIG RAM
    FCP; AE; PS; DSP
    John Pale replied 19 years, 8 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    January 19, 2007 at 7:54 pm
    What settings are you using?
  • John Pale
    January 19, 2007 at 8:11 pm
    Also it takes much much longer to use the “Export to Compressor” option than it does to just export a Quicktime reference movie and “manually” import it into Compressor.
    The reason is that if you use the “Export to Compressor” option, all the effects in the timeline are re-rendered directly to MPEG-2, instead of using the render files you created in editing. This can make things take an enormously long time, though it can produce a slightly cleaner encode….but in many cases the difference is not noticable. I only use this option if I am unsatisfied with the results of the other method.
