Activity › Forums › Adobe Premiere Pro › AME Encodes different from PPro encodes…read on
  • AME Encodes different from PPro encodes…read on
    Posted by Duke Sweden on March 20, 2017 at 10:14 pm
    ok, take one video clip. Export media. Choose DNxHD/DNxHR etc format. Preset DNxHR 4K 24p. This will give C4K dimensions, 4096×2160 24p. If I encode using Premiere Pro, that is precisely what I get, and when I drag it to the timeline, that is what I’m seeing in the Program window.
    However, if I choose “queue” and encode it using Media Encoder, same format, same preset, same specifics (4096, etc.) that is what I get, BUT, when I drag it to the timeline, I can see that it’s squeezed by 1/2″, with black bars 1/4″ thick on both sides in the Program window. The info panel says the same as it does for the PPro encoded file, 4096×2160 at 24fps. But it doesn’t fill the window. You can clearly see that it’s being squeezed. It’s not missing pixels. It’s like anti-anamorphic.
    Is anyone else experiencing this? It’s a pain to transcode my clips one at a time using PPro.
    Pat Horridge replied 9 years, 6 months ago 3 Members · 2 Replies
  • Tero Ahlfors
    March 21, 2017 at 4:58 am
    What are your sequence/export settings? What is the resolution of the source file?
  • Pat Horridge
    March 21, 2017 at 1:06 pm
    Sounds like the rcport ends up UHD at 3840 wide. And is then padded back to 4096.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
