Activity Forums Adobe Audition Ambient noise affected the interview
  • Ambient noise affected the interview
    Posted by Mariusz Potyralski on April 3, 2020 at 5:29 pm
    Dear colleagues,
    Hope you are all keeping well.
    Could you please express your opinion on below video in terms of the sound of the interview.
    https://youtu.be/JJA5blVUycY
    I’ve almost finished creating my recent video project. I am very grateful and fortunate as this is a big client with potentially more work in the future – if they will be pleased with what I have produced for them.
    The problem is the ambient noise of the interview. So far I’ve used You could hear the sound of the fountain at the background. So far I used those effects, but I am still not satisfied with the sound.
    *Parametric equaliser/cut off Hi & Low frequencies
    *Noice reduction/the noise point
    *Highpass to cut off anything below 400Hz
    *Dynamics/Auto Gate settings
    Please let me know what do you think I should do in order to make this video sounds best.
    Cheers,
    Mariusz
    Andy Ford replied 6 years, 3 months ago 2 Members · 1 Reply
  • Andy Ford
    June 8, 2020 at 11:25 pm
    Two things you can do. I know you said you tried Noise Reduction, but there is a delicate balance between finding a clean noise print of the sound and removing just enough to not affect your talk track. Sometimes, I run it a few times. I have a tutorial on that here:
    https://youtu.be/zVgK2_9xOg0
    Also, you can go to the spectral view of your audio and try to use the healing brush or delete tool to remove the small area of the noise if it is concentrated in an area that isn’t in a similar range to your other audio.
    Video Producer / Digital Marketer / Gear Reviewer / Author
    —– http://www.AndyFordVideo.com —–
