Activity Forums Avid Media Composer AMA works and then just stops connecting
  • AMA works and then just stops connecting
    Posted by Philip Coccioletti on February 6, 2015 at 7:23 pm
    We converted some large files from an FS7 camera to Apple Pro Res HQ.
    We went into AMA volume and it showed all the files fine .
    I got up to make a call… came back and everything was off line and we could not hook up the AMA volume again. Whats up with that?
    The actual pro res Qt’s are not even highlighted in AMA volume, but if you select AMA files they are highlighted and will import.
    Even though we had all the media in the bin and it was off line… why doesn’t relink ever work
    phil
    Philip Coccioletti replied 11 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
