Activity Forums Avid Media Composer AMA NTFS Drives
  • AMA NTFS Drives
    Posted by Eric Santiago on November 26, 2018 at 10:39 pm
    I am sure the answer is simple.
    I have over a dozen USB3 NTFS formatted drives.
    All RED files and no resources to copy to a faster RAID.
    I finally purchased Paragon and I am still seeing the NTFS oddities.
    One is the DRIVE path.
    That keeps changing with some of the drives.
    I had to RELINK all AMA again via drag and drop with OPTION key selected.
    None of the RELINK settings worked.
    Crossing fingers that once all this is done (again), Avid will at least now RELINK properly.
    The last few days were hell since each of these awful drives were named MYBOOK.
    Yes, I am that dumb to take on this project 😛
    Eric Santiago replied 7 years, 9 months ago 1 Member · 1 Reply
  • Eric Santiago
    November 26, 2018 at 11:01 pm
    Ooops forgot to add what the paths look like.
    It toggles between:
    USBDRIVE001
    and
    /Volume/User/USBDRIVE001
    Nothing to worry about?
