Activity › Forums › Avid Media Composer › AMA linked video and effects in Media Composer
  • AMA linked video and effects in Media Composer
    Posted by Gillian Ryan on June 16, 2011 at 3:32 pm
    Hello,
    I have linked my media using Link to AMA volume in media composer. I am trying to add effects to the video and for some reason it will not work. I was trying to slow down a clip using timewarp and it says, this effect does not apply. I also tried making a freeze frame and when I picked my frame and went to the pull down menu it will not light up as an option? Not sure why nothing is working? Is there a way to get this all working??
    thanks in advance.
    Gillian
    John Pale replied 15 years, 3 months ago 3 Members · 2 Replies
  • John Cuevas
    June 16, 2011 at 7:32 pm
    As far as I know, the answer is to import the footage into Avid that you want to add effects. You can also do a video mixdown to selected clips. Transcoding the footage will also work…
    AMA works real well in some situations and not so great in others.
    Johnny Cuevas, Editor
  • John Pale
    June 16, 2011 at 8:28 pm
    Is there a green dot on the clip?
    This means a motion adapter has already been applied….as the ama clip does not match your project settings.
