Activity › Forums › Avid Media Composer › AMA link to ProRes 4444 shows up as Matte Key files?
  • AMA link to ProRes 4444 shows up as Matte Key files?
    Posted by Daniel Neutzsky-wulff on September 6, 2013 at 1:15 pm
    I’m very new to Media Composer 7 and I’m doing a switch from FCP/Premiere Pro.
    I have a bunch of ProRes 4444 MOV files that I’m trying to AMA link to. The problem is, that once I link to the files they show up as these “Matte Key” files instead?
    I can’t edit them or anything, what am I doing wrong?
    Best Regards,
    Daniel
    Michael Phillips replied 13 years ago 2 Members · 1 Reply
  • Michael Phillips
    September 6, 2013 at 3:02 pm
    You need to go to your Import settings (not AMA) and make sure you set alpha to none. This will be addressed in an update to at least be in the AMA settings, and not import…
    Michael
