Activity Forums Avid Media Composer AMA Ghosting?
  • AMA Ghosting?
    Posted by Brendan Maghran on March 28, 2011 at 6:02 pm
    Hi Everyone,
    I was just in the middle of running some tests. AMA/transcode vs. direct import of both RGB and 709 levels when I discovered mysterious Ghosting on the AMA footage, but not any of the direct import footage. Check it out, any ideas as to why? It’s all the same Canon SLR H.264 23.98 footage. The AMA image is top right, 709 import on the right and RGB import on the bottom. DNxHD 115 footage.
    Jeff Greenberg replied 15 years, 5 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    March 30, 2011 at 10:51 am
    I don’t know what’s causing it…
    It looks like it’s displaying both fields. Could you step through and see if it has the same sort of look on field 2? (Open the effect palette, move, step forward 1 field.)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
